Author Topic: Cayman fuse trip  (Read 1958 times)
Lunty
  • Boat Model: Bavaria 37
Cayman fuse trip
« on: June 04 2021, 07:35 »
Which one of these fuses is for the anchor cayman winch they both seem really heavy duty and how can you tell  if they have tripped
Re: Cayman fuse trip
« Reply #1 on: June 04 2021, 08:29 »
NH fuses are available with a red indicator dot that pops off when they melt. Yours do not have it, so you can tell they triggered when the boat is dark or the windlass not working :))
It should be easy enough to follow the cables to see which does what - on ours the 100A is for the windlass, 125A for house bank. Get a white marker pen or some labels and start marking the cables - it'll be helpful later!
« Reply #2 on: June 04 2021, 09:01 »
Pull them out one at a time and put a continuity meter across them.
Lazy Pelican
« Reply #3 on: June 04 2021, 09:33 »
On our B392006 it’s the fuse on the right- don’t ask how I know!
Lunty
« Reply #4 on: June 04 2021, 11:54 »
the both fuses are fine the anchor dropped ok then retrived ok till it hit home then it stopped and never worked again
SimonS
  • Boat Model: Bav 32
« Reply #5 on: June 05 2021, 21:37 »
Try moving the windlass manually with the handle.  It worked for me. I suspect the motor had stopped on a dirty patch on the commutator. and th nudge moved it sufficiently.
