Author Topic: Calira Sealine panel 420 question  (Read 2551 times)
Haveago
  • Boat Model: BAV 31
« on: April 10 2021, 00:45 »
Hi - could anyone help me identify what the icons circled in red in the attached photo (from my 2001 Bav 31)  control panel refer to?  Probably a really stupid question!
Re: Calira Sealine panel 420 question
« Reply #1 on: April 10 2021, 08:40 »
Select water tanks 1 or 2 - if you have 2 tanks. If you only have one tank you will get a reading if you press the one on the left. Same with the voltmeters for the batteries.
diverphil
  • Boat Model: 33 cruiser
« Reply #2 on: April 10 2021, 08:43 »
from left to right battery no1, battery no2, low battery warning , mains connection. tank level no1 , tank level no2.
they are the same signs on ours but in a different position, guess that when you push the switch the reading comes up on the digital display.
have you tried google for a manual, or there may be one on here if you use the search box.
regards
phil
Haveago
« Reply #3 on: April 11 2021, 22:17 »
Brilliant - thanks diverphil and symphony2
