Author Topic: Fuel Tank - Size & other bits  (Read 2855 times)
dcreedon
« on: November 22 2020, 17:04 »
Hi, I've a Bavaria 36 2002. 3 Cabin version with a 29HP Volvo Penta 2030. I think I have a 150L Diesel Tank it has a 150D marking on it. See attached picture. Can anyone confirm it's a 150L tank ?  Also the two nozzels? next to the feed and return pipes, anyone using these?
Re: Fuel Tank - Size & other bits
« Reply #1 on: November 22 2020, 19:10 »
Yes, 150l and 150l water on the other side. Optional 150 water up front.
dcreedon
« Reply #2 on: November 22 2020, 19:12 »
Thanks, thought so.
artemis
« Reply #3 on: January 16 2021, 14:13 »
you could use the blank nozzles for a eberspacher heater or any other make.
Mike
« Reply #4 on: January 16 2021, 18:49 »
I'm using one of the extra nozzles for a sample pipe that goes to the bottom of the tank, which also doubles as dipping stick to determine the accurate tank level (the gauge is more approximate).
We pump out the dregs from the bottom corner of the wedge-shaped tank every winter with it.
« Reply #5 on: January 17 2021, 09:38 »
Do the extension pipe’s on the fittings exist as standard?  If so are they of different lengths?
Harveyhall
« Reply #6 on: February 09 2021, 03:44 »
Hi decreedon
Not sure about other 36’ owners with a 150 litre tank, but after running out of fuel once I now calculate 1.8 litres per hour and my tank at 110 litres to play it safe. My spreadsheet and my calculations haven’t let me down. (Engine Volvo MD2030)
