Bavaria Yacht Info
The FREE Bavaria Yacht Forum
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Login
Register
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
Furlex 300s
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Furlex 300s (Read 2353 times)
buttonfreebie
Second Mate
Boat Model: Bavaria 41
Boat Year: 2004
Furlex 300s
on:
November 10 2020, 08:50 »
Does anyone know how to get at the 4 screws B4 on the Furlex lower swivel parts diagram. 3 of the screw have worked out and are now tight against the inside of the tack ring , part B8 I hope I don’t have to remove the complete unit
Logged
Administrator
Boat Model: 40 Ocean
Boat Year: 2001
Re: Furlex 300s
Reply #1 on:
November 10 2020, 10:33 »
I might be wrong, having done this only once a few years ago, but I think you can slide the B1 collar upwards onto the foil after removing 2x B2 screws. That should get you access to the B4 undernearth.
Logged
(formerly)
Sailing Songbird
⛵️ Bavaria 40 Ocean (2001)
buttonfreebie
Second Mate
Boat Year: 2004
Re: Furlex 300s
Reply #2 on:
November 10 2020, 15:29 »
Yes B1 can slide up revealing only the top 1/8 th part of screws B4 . The rest of the screw is hidden behind the tack ring B8 and that is the problem how to get access !
Logged
Administrator
Boat Year: 2001
Re: Furlex 300s
Reply #3 on:
November 10 2020, 17:38 »
I see. Never had cause to take it apart that far, but in the exploded drawing it looks like the tack ring must come off downwards, and the only part preventing it from doing that is B13, which is encouragingly labeled as "Clip ring". So I'd have a good look at that - it's probably some sort of circlip or similar. Be prepared for the loose bearing balls from both upper and lower races to drop out, so best tape a plastic bag in place to catch them.
Ah, a quick search hints that the retaining ring is a Spirolox type. Removal and installation videos here:
https://new.engineering.com/story/what-you-need-to-know-about-spiral-retaining-rings
Good luck and don't drop the balls!
Logged
(formerly)
Sailing Songbird
buttonfreebie
Second Mate
Boat Year: 2004
Re: Furlex 300s
Reply #4 on:
November 11 2020, 08:13 »
Thank you Yngmar I will take a close look as soon as I can get to the boat which is ashore in Rhodes shipyard and I am at the opposite end of the island. Regards Graham
Logged
Print
Pages: [
1
Go Up
« previous
next »
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
Furlex 300s
