Author Topic: Propeller code 713  (Read 2662 times)
elias
Propeller code 713
« on: October 06 2020, 14:28 »
Found this prop while snorkeling !
I think is for volvo saildrive cause it matches a lot , is almost new and has marked code 713. Any ideas ??
Re: Propeller code 713
« Reply #1 on: October 06 2020, 15:00 »
It will be 17x13 ,so for a saildrive /engine about 40hp Geoff
elias
« Reply #2 on: October 06 2020, 20:14 »
Thanks for the info , I ll put it for sale on EBay since I already have on spare . If any of you is interested text me.
« Reply #3 on: October 06 2020, 21:21 »
I think the figures you are looking at are not 713, but are .. /13. Usually the prop size is marked as diameter/pitch or pitch/diameter so you need to check the diameter of the prop to see if it is 13 inches or significantly more or less, and that will then tell you whether the 13 refers to diameter or pitch.
« Reply #4 on: October 07 2020, 08:25 »
You can quite easily measure the propeller diameter and also pitch.
Good instructions, templates and and app can be found at https://sites.google.com/site/thepropellerhub/simple-pitch-measuring
BR,
Tommi
s/y Anniina
elias
« Reply #5 on: October 07 2020, 17:44 »
Sorry guys , I just noticed that has a code 21381275 17X13 LH . Volvo 15-17
