Author Topic: Seldon in mast furling system  (Read 2919 times)
Sootydog
  • Boat Model: 39 Cruiser
« on: October 05 2019, 19:02 »
Is there any preventative maintenance that I should be performing end of season for the curling system?
elias
Re: Seldon in mast furling system
« Reply #1 on: October 06 2019, 08:38 »
Hi! Mainsail out washed and packed , the pulleys of the outhaul covered for Uv protection , fresh water to the drum attached to the must and then grease , grab with your hand the shaft inside the mast if is stiff enough ( maybe you notice that on anchor and some waves make the must bang like a bell cause of that ) if it is loose take the manual and look how to adjust the tension
Sootydog
« Reply #2 on: October 06 2019, 13:05 »
Elias, exactly where on the drum to you apply grease? I can't see an obvious grease point. Is it hidden within the mast? Will I need the remove the drum assembly?
« Reply #3 on: October 06 2019, 14:01 »
You can download the service manual from the Selden website.
elias
« Reply #4 on: October 06 2019, 16:41 »
And spray with a the tiny hose on the ball bearings of the drum
Sootydog
« Reply #5 on: October 06 2019, 19:01 »
Elias, got it ! Many thanks.
