Author Topic: Holding tank pipe from heads  (Read 2950 times)
Fenders
« on: May 21 2019, 19:30 »
I recently noticed some corrosion on the metal elbow that is located on the top of the holding tank. It is connected to a hose that comes from the heads.
I am considering replacing this metal elbow but I see that it appears to be integral to the plastic tank.
Is it possible to remove this or is it a case of buying a new tank complete with fittings.
I'd hate to have the experience of one of this forum's contributors who described his "exploding tank", which I think may have been  caused by a blockage.
The boat is a 2004 B32.
Re: Holding tank pipe from heads
« Reply #1 on: May 21 2019, 21:48 »
We have a similar elbow on the bottom of our holding tank. It's simply a threaded elbow with a nut on the inside retaining it. Technically accessible via the inspection hatch, but practically you'll need a bloody long extension to get at the nut.
« Reply #2 on: May 21 2019, 22:14 »
Would not worry too much about that surface deposit. Probably a slight leakage has caused it and it is salt deposits rather than corrosion of the metal. Clean it up, check all the connections and keep an eye on it.
« Reply #3 on: May 22 2019, 07:21 »
Quite agree, also it looks like the elbow is made of bronze so the corrosion is not rust as such and I doubt if it’s due to leakage through the metal. More likely either leakage through from a deck fitting above, or from condensation dripping off a low point, particularly if you spent time onboard during the winter and had a heater running. Suggest you try the blue tissue paper trick and suspend a sheet of the stuff horizontally above the area but not in contact with it and see if the paper gets wet.
Fenders
« Reply #4 on: May 22 2019, 19:56 »
Thanks for all your replies.
They have given me some direction regarding the cause of the corrosion.
The elbow does look like a bronze fitting. Strangely enough above the holding tank I have some clips where I store a deck brush and a sponge mop. The heads of these hang directly over the holding tank and maybe over a long period of time water has dripped from the brush and mop onto the top of the holding tank and elbow.
I was on the boat today and used a small piece of wet and dry on the corrosion. The corrosion appears to be only on the surface so that would suggest to me that the cause is not internal.
I will keep a close eye on it just in case.
Thanks again for your guidance
Fenders
