Author Topic: Heads seacock: thread size?  (Read 5646 times)
« on: January 06 2013, 13:31 »
I need to replace the larger size of seacock from the heads on my Bavaria 47. Does anyone know what size thread they are?
njsail
Re: Heads seacock: thread size?
« Reply #1 on: January 07 2013, 02:03 »
I don't know the thread count but I know I replaced 2 of the big through hull/sea cocks with 1 1/2".   They were the same size as the original ones.  I'm not sure if you're looking for the diameter or the thread count.
« Reply #2 on: January 08 2013, 13:04 »
I have a photo of all the valves and numbers, the threads are BSP standard so look up the standard:-
BRASS BALL VALVES
TECHNICAL & DIMENSIONAL DATA
SPECIFICATIONS :
FULL BORE BALL VALVE , TWO PIECE DESIGN, LEVER OPERATED,
SCREWED FEMALE BSP PARALLEL THREADS TO BS21.
Look at Photo and put numbers into Google.
njsail
« Reply #3 on: January 09 2013, 02:22 »
outstsnding documentation Odysseus.  those are not the seacocks that were on my boat.  now you have me wondering what was on my boat.  i tossed them all thinking i would never need them again.
« Reply #4 on: January 11 2013, 11:35 »
Thanks chaps, so 1½" BSP then.
