Author Topic: Anodes  (Read 3255 times)
Impala
  • Boat Model: 38 Cruiser
Anodes
« on: May 23 2018, 09:12 »
Hi Everyone,
We have a Bavaria 38 2003 which is about to come out of the water. Where do I find out which anodes we need to buy?
Many thanks,
Re: Anodes
« Reply #1 on: May 23 2018, 09:31 »
Look at the type label on top of your saildrive's gearbox. This will tell you which model saildrive you have, which determines the kind of anode you need.
Re: Anodes
« Reply #2 on: May 23 2018, 10:15 »
If it has the original engine and drive (either a 2030 or a 2040 engine) it will need a one piece anode for the 120 saildrive. However if you have a rope cutter fitted you will need a modified anode available from www.ropestripper.com You will need to remove the propeller to change the anode.
Impala
Re: Anodes
« Reply #3 on: May 23 2018, 16:38 »
Hi Guys,
Many thanks for the swift replies!
Re: Anodes
« Reply #4 on: May 23 2018, 22:59 »
Should perhaps have added that if you have a feathering or folding prop it may well have its own anodes.
