Author Topic: Privacy Blind  (Read 5474 times)
Noelio Abrunhosa
Privacy Blind
« on: August 19 2017, 21:35 »
hi All
the other day while siiting in the saloon i decided that i needed a blind for the companion way on Po-go.
so got the brain matter workind and decided to make a blind that can clip on and off on press studs and also tried to incorporate the bavaria logo. here is a pic of it. maybe we should go into business making these.
have a great weekend
Abby
Re: Privacy Blind
« Reply #1 on: September 12 2017, 00:15 »
Hi Abby,
I've been thinking along exactly the same lines myself for some time now, but was going to use Velcro to secure the blind in place. For the time being I've just used a rectangle of cloth which jammed between the hatch and the door and only covered the door. I like your Bavaria logo design.
Noelio Abrunhosa
Re: Privacy Blind
« Reply #2 on: September 15 2017, 13:49 »
hi.
i first thought of using velcro but decided it was going to be a eye sore. the press studs were cheap and easy to fit.
Noelio
Irmascherkid
  • Boat Model: 30 cruiser
Re: Privacy Blind
« Reply #3 on: September 26 2017, 13:02 »
Now that's cool, did you fasten it to the plexiglass or to the size of the companion way?
pjl
Re: Privacy Blind
« Reply #4 on: September 26 2017, 19:32 »
One of the best mods on our boat.
We have if fastened at the front of the hatch with the same things that are used with the sprayhood and we have a round window in the center to let in some light  :kewl
Ours is like a curtain: When not needed, we just llift it up and let it stay on top of the hatch as it is slides in. During the warm summer nights the plexiglass door stays off the companion way all the time and when the plexiglass door is in place the curtain sits again on top of the hatch.
Love it.
Noelio Abrunhosa
Re: Privacy Blind
« Reply #5 on: September 26 2017, 21:06 »
Hi it clips on the inside of the companion way. i used 4 12mm press studs
Regards
Abby
Re: Privacy Blind
« Reply #6 on: September 27 2017, 10:38 »
I have put this on before but added more this time.
I have had a screen on the companionway for years it works great and tucks up under hatch as you slide it open. You can see it in open position.
Second I have now 2 shade covers on bungee over bow and midships hatches, these keep the sun off the inside when hatch is open also if it rains no water comes in.
Simple to make but very effective.
Hope this helps.
Bav 38
Kibo
  • Boat Model: Vision 46
Re: Privacy Blind
« Reply #7 on: January 30 2018, 20:40 »
On the subject of blinds..... nice work by everyone. Here is our idea.....
We used to live in Japan where the privacy screen/curtain is very common. Called a "Noren" in Japanese.
We bought a few of these and they hang on a simple cane so very easy to put across your companionway and remove for entry. No snaps or drilling required. Easy to make too. Just make a curtain with a seam at the top you can slide a cane or dowel through.
You can close the hatch or even the doors/washboards too.
Ian
