Author Topic: 2006 BAVARIA 42 FOOT CRUISER  (Read 5728 times)
russ
  • Live the Dream
  • Boat Model: Bavaria 42 cruiser
« on: July 24 2017, 22:27 »
Hi my hot water tank appears to be leaking. Has anyone replace their hot water tank? IF so where did you buy it? Has any one fixed a their hot water tank?
Ziffius
Re: 2006 BAVARIA 42 FOOT CRUISER
« Reply #1 on: July 24 2017, 23:31 »
had to replace mine on Bav 39 - had to take what i found in Corfu Chandlery - some italian made thing- it was only thing available at short notice. Holding up so far but chewed through the anode which I cant find replacement for - had to have one made. See what make yours is - probably a QL in yours.
« Reply #2 on: July 25 2017, 08:32 »
Russ,
Do a search in 'Member Forums' for 'Calorifier' - plenty of info  ;)
PEA-JAY
  • Boat Model: B-Cruiser 39
« Reply #3 on: July 25 2017, 12:50 »
Hey Ziffus by "Italian made thing" you mean like Ferrari, Maserati, Grand Solei, Perini Navi quality?
solar
« Reply #4 on: July 25 2017, 13:31 »
SVB24 is your friend in this search.
patprice
« Reply #5 on: July 27 2017, 06:58 »
Anode ! Do all have an anode. Where is it?
« Reply #6 on: July 27 2017, 09:47 »
[/quote]
[/quote]
    Yeh, ditto, mmh? Now I'm  a little worried.
« Reply #7 on: July 27 2017, 11:03 »
Not all calorifiers have an anode. Depends on the materials they are made out of.
« Reply #8 on: July 27 2017, 11:35 »
Just a thought russ, does your system have a pressure accumulator fitted? Ours doesn't, so when the engine is running or the immersion heater is switched on there is a tendency for the pressure to rise and the pressure release valve operates allowing a little water to be released into the bilge, this could look like a leak.
 I should really get around to fitting one, this would avoid mopping up the dribbles ever few days. :-[
Ziffius
« Reply #9 on: July 29 2017, 09:19 »
@Pea-jay. - could be any of those as there wasn't a makers mark on it just the specs were in Italian:)
Stuart
« Reply #10 on: August 07 2017, 15:31 »
Hi Russ, we replaced our Bavaria 42 2005 water tank with a similar sized "Isotemp" tank
Stuart
« Reply #11 on: August 08 2017, 12:51 »
On our 2010 Bav 38 QL  ( the original tank) had a leak in the heat exchanger resulting in fresh water from the tank entering the engine heating pipes and forcing water out of the engine header tank when the fresh water pump was on.
Replaced with a "Quick" brand, but had to install a slightly smaller tank to fit. No worries since. I did find that the Quick tank's insulation was not good so I squirted expanding polyurethane expanding foam around the tank. Seems to keep the tank hotter, longer.
Make sure you don't over tighten the hoses to the tank. When our new tank was installed the Turkish installer broke the weld between the pipe connection and the tank.
" Shirley Valentine"
