Author Topic: Cruiser 37 Chainplate cover  (Read 5291 times)
Asylum2.0
« on: May 03 2017, 13:20 »
Hello all,
I have a 2014 Cruiser 37 and have noticed some colored water weeping out of the chainplate covers along the toerail.
Does anyone know how to remove the covers to inspect the chainplate fittings?
Ed
Re: Cruiser 37 Chainplate cover
« Reply #1 on: May 03 2017, 14:08 »
It is more likely to be 'rusty' water coming off the rigging.The chainplate covers are normally water-tight.
« Reply #2 on: May 03 2017, 14:44 »
Just to clarify, do you mean the stainless plate around the chainplate, or the fibreglass cover below the toerail?
Asylum2.0
« Reply #3 on: May 03 2017, 14:55 »
Fiberglass cover
« Reply #4 on: May 03 2017, 15:03 »
Fiberglass cover
OK, yes, water will leak out of that - it isn't watertight as dawntreader claimed.  Indeed, it's surely preferable that water can drain out of the area.  I imagine the cover is simply glued on with sealant.  The chainplate is attached to the hull moulding with 8 meaty stainless nuts and bolts, and it's possible that slight surface rust is responsible for the coloured water you've seen.
Asylum2.0
« Reply #5 on: May 03 2017, 16:11 »
The colored water has a greenish tint to it.  I'm thinking pollen as the whole boat washes geeen in the spring.
I've tried to flush it clean but not to my satisfaction.
« Reply #6 on: May 03 2017, 16:40 »
Rather than taking off the fibreglass side cover, you might try lifting the stainless plate on the deck and using a bottle brush to clean inside the cavity.
Asylum2.0
« Reply #7 on: May 10 2017, 11:44 »
Thanks Tiger,
I see the stainless plate is fastened by two small phillips head screws.  It also seems to be tucked under the toe rail.
Do I need to release the toe rail screws to slide the plate out?
« Reply #8 on: May 11 2017, 19:04 »
Sorry, I don't know the answer, maybe trial and error...
KimKiegstad
  • Boat Model: Cruiser 36 Avantgarde
  • Boat Year: 2012
« Reply #9 on: July 27 2017, 21:37 »
Did you ever found out how to clean behind the chainplate covers?
Asylum2.0
« Reply #10 on: July 29 2017, 01:46 »
No luck.
I powerwashed the boat and flushed it clean.
No staining yet.
Would still like the get in there to inspect.
