Author Topic: Drying out bav 38 lead keel  (Read 6749 times)
Clouds
« on: January 29 2017, 21:15 »
Hi this is my first post on this forum. I'm considering a circa 2003 Bav 38 with the deep lead keel and wondered if anyone on this forum has experience of drying one out (10metre tide range!) alongside a wall or jetty?
I would not plan to do this often probably just the odd overnight and typically on a concrete drying pad. The primary benefit would be a for quick jet wash, antifoul, anode change between tides, rather than the £500 I would pay for a lift in my marina.
I want the deep draft lead keel to maximise performance. I have owned shoal draft and while theoretically as stiff they have shorter rudders to prone to lose grip when on the limit.
Thank you for any advice.
Re: Drying out bav 38 lead keel
« Reply #1 on: January 30 2017, 08:22 »
It is feasible to do this on a drying pad. I think you will find the deep keel is made of pig iron not lead - but I could be wrong. If it is pig iron it will need more work to clean and prepare than you may think. I have been doing the anti-foul on my boat for 10 years now and it takes me 3 hours to do 1 coat of Cruiser Uno (a popular anti-foul brand) from end-to-end. This does not include preparation time. I think you will be struggling to do all the jobs in one [tide] and you may want to consider planning to do them over a couple of cycles.
Clouds
« Reply #2 on: January 30 2017, 23:35 »
Thanks. It is advertised as a deep lead keel but cannot find any detail on its shape, I'll double check.
I'd have about 8hours so plenty time to antifoul and anode change. Perhaps every other year I would cradle her for a proper job.
« Reply #3 on: January 31 2017, 00:51 »
Allow enough time for the paint to dry :)
The default shallow draft keel (cast iron) is a bulb shape (data sheet with sketch), while the upgraded deep draft (lead-antimony) is a dorsal fin type, as depicted here:
It may need support under the bow to keep it from pitching over forwards (at the very least trim weight aft), but can rest on the keel just fine.
Clouds
« Reply #4 on: January 31 2017, 07:13 »
Brilliant many thanks.
I think I would risk drying out on that keel. For the first time I'd have a pole to support the bow.
On previous boats I've powerwashed and antifouled over a low water. Though I'm considering coppercoat and I would then just have to power wash once or twic a year.
A lot cheaper than the £500 a proper loft costs. :D
Fenders
« Reply #5 on: January 31 2017, 07:43 »
Clouds
I think you are correct regarding the lead keel.
My 2004 Bavaria 32 also has a lead keel.
Apparently it was a factory fitted option.
Mine is ashore at the moment being antifouled and is next door to another 32 of a similar age.
The other one has a cast iron keel and requires a lot of attention due rusting and pitting.
Fenders
  • Boat Model: Bavaria 37
« Reply #6 on: January 31 2017, 09:39 »
On a slighty different note - I tend to find that my Bav 37 (shoal draft) tends to want to sit back on the rudder - hence I put the support in (well actually a friend in a wetsuit did!)
singlefish
  • Boat Model: 38
« Reply #7 on: February 02 2017, 08:40 »
I can assure you my bavaria 38 2003 with manufacturers ( wouldnt think there would be any third party keels ) lead keel is a standard deep fin with flat bottom , no bulb , no sweeping curves , flat deep and solid lead
singlefish
  • Boat Model: 38
« Reply #8 on: February 02 2017, 09:12 »
B38 2003 deep lead keel
singlefish
  • Boat Model: 38
« Reply #9 on: February 02 2017, 09:24 »
Ps the deep keeled b 38 of the 2003 era is a fantastic boat , very fast , very easily handled by two , excells in all departements , with 55 hp cream on the cake !
Much admired with its timeless looks .
Weve cruised all over west coast scotland for which its ideal , fast easy passages , ability to motor into anything if required ,
Cruise mainly ,every weekend and holiday my wife and i .
And won many white sail races , infact 3rd worst result
Infact dont let anyone say they dont go upwind , we were 3rd across the water in a race 25 miles upwind in a force 4-5 only just behind a sunfast 40 , ahead of first 40.7 only beaten by "drum " the 70 foot maxi on hcap .regularily beat benny 37'9, 409' s and 2:1 in our favour against starlight 38 ,all across the water , up and down .
Easily depowered rig that can be flattened off and full sail carried up to 25 knots if it takes your fancy .
Tons of room , we love ours , heading into our fifth season
Clouds
« Reply #10 on: February 03 2017, 07:05 »
Brilliant response many thanks. This is a top forum where the responses are actually useful!
Clouds
« Reply #11 on: February 03 2017, 07:57 »
Hi Singlefish,
Your sailing requirements mirror mine. Any tips or modifications for maximising performance. I'm guessing you have decent sails and a folding prop to be performing so well? And a clean bottom :)
singlefish
  • Boat Model: 38
« Reply #12 on: February 05 2017, 00:46 »
Yes , ive got a vectran main , lightdacron with vectran weave through it , sets beautifuly and is supposed to keep its shape for at least 10 yrs , cost same as a heavier best dacron , and a properly cut genoa , best dacron ,
Clean bottom most of season ,
Volvo three blade folding prop , makes huge difference over fixed , no lack of performance under motor either . For sailing performance a folding ,feathering prop is a must .
Otherwise up wind flatten sails off and pull,them in , tight ! The b38 rig is amazingly versatile .
Good luck
