Author Topic: Draining calorifier  (Read 4696 times)
Noelio Abrunhosa
Draining calorifier
« on: January 29 2017, 19:10 »
the electrical element in the hot water heater trips the breaker when it gets switched on. what is the procedure for draing the calorifier to be able to replace the element. didnt see any obvious drain points.
regards
Re: Draining calorifier
« Reply #1 on: January 29 2017, 20:12 »
Unless you have some obvious service cut-off valves it will have to be all run off through the taps  :-\
« Reply #2 on: January 29 2017, 21:39 »
It'll drain quite quickly once you remove the element  :))
Noelio Abrunhosa
« Reply #3 on: January 29 2017, 21:50 »
 :) i am aware of that. i just finish cleaning and drying the bilges. didnt want to do that again in a rush. but it looks like the only option
Abby
« Reply #4 on: January 30 2017, 07:50 »
On my boat (B36/2002) the calorifier is plugged into a mains socket under one of bunks. First thing before doing anything else, is to pull the plug so that the electricity to the heater element is absolutely cut off, no if's, but's or maybe's about it. Then to be doubly sure, unplug your boat from your shore power supply.
Next, you may be able to get a shallow tray, or hopefully a deeper tray, under the end where the water connections are located. Prop up the forward end of the tray as needed to keep the tray more or less level.
Make sure that your domestic water pump is turned off, and ideally if fitted close your water tank isolating valves to prevent or at least reduce any subsequent leakage or seepage where a system might not be as tight as hoped.
One at a time slacken off the domestic fresh water inlet and outlet connections to the calorifier, allowing the water to trickle into the tray, and with a sponge, bale out the tray into a bucket before the tray overflows into your bilge areas. When no more water comes out of the first connection that was slackened off, leaving it slack, then start to slacken the second connection which may allow more water to trickle out of the first.
Check that there will be enough space in front of the calorifier to withdraw the electric heating element, if not, you may have to unbolt and move the calorifier sufficiently to allow for heater removal, and that might mean having to disconnect the hoses from the engine cooling water system. When no more water comes out from the slackened connections, then start to unscrew the heater element. With the faulty element out, replace it with a new element and re-secure the water connections.
Make sure that the work area is properly dried out, and then open any isolating valves and start your water pump. If there are no leaks, turn on one of the taps which has been set to provide hot water, and clear the heater of air. Attend to any water leaks that might now appear, and when you are sure that the pipework is free from leaks, then plug the heater back in to the socket under the bunk. Plug in your shore power, and switch on the heater for the calorifier.
Hopefully you now have success, and your bilges have remained dry.
« Reply #5 on: January 30 2017, 08:13 »
As an afterthought, have you sourced a replacement yet? I found that they are available in UK domestic suppliers and therefore less expensive than those supplied by marine sales outlets. The one I bought also came with a tool to tighten it (large spanner).
Noelio Abrunhosa
« Reply #6 on: January 30 2017, 08:31 »
 hi. thanks for the info. going to the boat on wednesday and will have a go at this. i ordered from ebay a small bilge pump which hopefully will drop it in a tray and runa hose to the sink.
enjoying all this work.
regards
Abby
« Reply #7 on: January 30 2017, 11:32 »
And one other thing I've just thought of, and that is to take a photo of the work area showing which hose goes to which connection etc., it's so handy when putting things back together and not having to think "was it this connection or that?"
Ricd
  • Boat Model: 34
« Reply #8 on: February 07 2017, 14:35 »
I drain calorifier every winter before taking boat out.  Easy to do.  Empty water through taps then crack open the water input joint on the calorifier and an output joint and collect water released in container.
