Author Topic: Volvo D2 55 Replacement for Air Filter  (Read 4078 times)
s/y Susanne
  • Boat Model: Bavaria 44/3
« on: November 06 2016, 13:05 »
Can anyone give me an Outside Diameter for the air inlet pipe that takes the rather poor OEM foam-filter and supporting spring for this engine.
I see from various threads that a double cone type filter has been used on other engines by those of us  not entirely happy to pay £35 for 2 grams of poly-ether foam.
For geographic reasons I am unable to measure my own inlet....anyone?
Stewart
Re: Volvo D2 55 Replacement for Air Filter
« Reply #1 on: November 06 2016, 14:42 »
I should be down there tomorrow so will let you know asap.
« Reply #2 on: November 06 2016, 20:48 »
The air filter has the same part number as the air filter for my MD 2020D, therefore the outside diameter of the air inlet pipe as previously measured is 66mm.
« Reply #3 on: November 12 2016, 14:09 »
I too have been thinking about a replacement for the sponge and spring. I have used domestic  cooker hood filter material which I glued together around a cylindrical mound (plastic pipe) It worked  but I got fed up making replacements (due to  a leaky exhaust which  quickly mucked up  the filter. So now I want a more solid replacement  - like a vortex filter on performance cars. Problem is there is not enough space between plastic pipe and side of engine block so it will be necessary to have a bend  and place the filter horizontally On my D2-55A which  I think is the same as yours  the outside diameter of the plastic pipe is 60mm (inside 45mm). I just happened to  have lying around a 60mm plastic elbow with internal rubber gasket which  should fit, the other end would take a 60mm internal diameter tube for the filter.  The pipe was from a boiler balanced flue (inner pipe) It should not be that difficult to find a filter with that dimension. If you are  going to  follow this approach  and identify a filter, I hope you will post the results.
« Reply #4 on: November 13 2016, 20:49 »
I have finished the job - used a sporty air filter from ebay cost £8. Now to upload photo.....
