Author Topic: Deck Light  (Read 3718 times)
Harry Brown
Deck Light
« on: August 22 2016, 08:07 »
Does anyone happen to know the part number for the Hella Deck Light?
Thought i would get a spare. Does a LED version exist?
Thanks.
suibhne
  • Boat Model: 36
Re: Deck Light
« Reply #1 on: August 22 2016, 08:59 »
If a LED version does exist check also the wiring to bulb
Filament lamps work with terminals reversed so either combination of terminals works.
LED lamps only work if terminal polarity is correct
Re: Deck Light
« Reply #2 on: August 22 2016, 15:34 »
It's a Hella FF work light. Mine had a corroded reflector and it was cheaper buying a whole new assembly including reflector on eBay than buying just the reflector as spare part.
I then replaced the halogen bulb with a cheap LED (a car headlight model, can't find the link atm), slathered everything in plenty of silicone grease and closed it up tight. It's been up the mast for a year now and through several storms - still working fine and lights the foredeck up brightly.
Harry Brown
Re: Deck Light
« Reply #3 on: August 23 2016, 07:17 »
Nice one Yngmar, thanks very much!:-)
