Author Topic: How to disable watertank 2 from Panel 301?  (Read 3287 times)
laatzu
« on: May 13 2016, 22:22 »
I have Bavaria 38 (2009) with only one water tank. On Panel 301, there are defined two tanks and tank 2 is alerting "empty" all the time :(
Does anyone know how to disable tank 2 from Panel 301? I had Bavaria 30 earlier, and there was only one tank on panel. Meaning that tank 2 should be possible to disable somehow from Panel 301.
Re: How to disable watertank 2 from Panel 301?
« Reply #1 on: May 28 2016, 11:34 »
You can access the rear of the panel by opening the twist lock screws with a quarter turn, and the panel opens like a little door. It should be possible to identiy the cables for the tank level measurement. Mine were plugged in wrong, which was confusing with front and back tank switch, so I interchanged them. If I rememder right, the cables are marked on the board.
Hope that helps.
laatzu
« Reply #2 on: January 01 2018, 10:18 »
Thanks for tip, but does not help :(
I am still struggling with this, there is "emty alarm" all the time on panel.
Any idea how to remove/disable Water Tank 2 from 301 panel.
