Author Topic: Bav 33C 2006 - shaft Sealing ring  (Read 4952 times)
CRYSTAL
  • Boat Model: B33C
« on: February 28 2016, 21:51 »
Hi guys,
any ideas where / what would be the cheapest way to get a new shaft sealing ring?
while bring down the rudder and cleaning the post, I noticed a round rusted spring coming down the shaft. Soon we realized that the spring came out of the shaft sealing ring (top part of the rubber boot) -  the ring (top part of the boot) is also rusted in one area and for sure not in good shape to go back in.
Bav Plus web site: https://www.bavariaplus.de/en/produkt/view/ahJlfmJhdmFyaWFwbHVzLXZpdXJyFAsSB3Byb2R1a3QYgICAgOaihQgM/?
So, has anyone repaired this or must I bite the bullet and order it from Bavaria.
Many thanks,
Hratch
CRYSTAL I
paulemeier1
Re: Bav 33C 2006 - shaft Sealing ring
« Reply #1 on: February 29 2016, 07:46 »
i have not done it by myself.
i just google the measurements with the german word "simmering" whats means sealing ring
several possipillitys for example
http://www.ebay.de/itm/65x100x10mm-Nitril-Gummi-Radialwellendichtring-mit-Strumpfband-Feder-R23-TC-/131728781792?hash=item1eaba5b1e0:g:6doAAOSwofxUf3hI
it should be the one you looking for. I am sure you get the same on your nearest eBay just search vor the measurements by paste and copy from your posts
« Reply #2 on: February 29 2016, 08:44 »
On the side of your old seal will find the serial number and identification. I ordered my replacement from here:
Simply Bearings: http://simplybearings.co.uk/shop/?gclid=CKbCjs_JnMsCFaISwwodsJMGsQ
Recommended  :tbu
ps they also supply o-rings for everything so if you need any or want to stock spares it would be a good idea to order these too and save on postage costs  ;)
« Reply #3 on: February 29 2016, 08:56 »
Got mine from Eastern Seals, who kindly inserted a stainless spring into it for no extra cost. Charged me £5 plus shipping.
Mine (B40O) was a 60x100x10 R23 NBR (Nitrile).
CRYSTAL
  • Boat Model: B33C
« Reply #4 on: February 29 2016, 14:57 »
Tnx guys. So how often are these seals changed ir better yet,  why not grease them up with waterproof grease under and over as the metal ecposed is crap and bound to rust again.
Anyone doing preventive maintenance on the seals?
ALB,
Hratch
CRYSTAL I
« Reply #5 on: February 29 2016, 15:27 »
Bought my boat second hand in 2010 when it was eight years old and changed the saildrive bottom bearings and the associated seal over winter 2010/2011. At that time it was noticed that the saildrive oil had water in it resulting in the oil going very cloudy looking. Also changed the saildrive hull seal at the same time which while it seemed like a good idea, it was actually a bit of a waste of money as the hull seal was found to be in very good condition.
CRYSTAL
  • Boat Model: B33C
« Reply #6 on: February 29 2016, 15:47 »
Just found the sealing ring on Simply Bearings .co.uk...
http://simplybearings.co.uk/shop/p25102/55x80x10mm-Nitrile-Rubber-Rotary-Shaft-Oil-Seal-with-Garter-Spring-R21-/-SC/product_info.html
excellent price and good web site.
Salty, we are also replacing the Saildrive oil seals..
these seals are designed for oil not salt water.... hence, good idea to stuff them with waterproof grease.
thanks,
Hratch
CRYSTAL I
« Reply #7 on: February 29 2016, 16:28 »
ALB,
I'd change them whenever dropping the rudder, which is hopefully quite rare. Do note that mine now has a stainless spring, which ought to be less prone to rusting than the standard spring. I slathered the whole bottom of it thick in silicone grease before putting it in there.
