Author Topic: Converting to german sheeting system  (Read 3933 times)
Konan the Bavarian
  • Boat Model: 37 Cruiser
« on: November 09 2015, 03:59 »
I am looking at converting my main sheeting system to the german sheeting system, and would be grateful for any pictures of how the sheets are routed along the deck, and how the first block is attached to the decl (or shroud base) after it leaves to boom. I have seen the websites of selden etc and their proprietary equipment, but it doesn't really help for the specifics of my 2006 B37cr.
All help & comments would be much appreciated.
Steven
SV Konan the Bavarian
Re: Converting to german sheeting system
« Reply #1 on: November 09 2015, 05:28 »
Found this - it is a Jeanneaus but  think it gives a clear picture
http://www.jeanneau-owners2.com/hintsandtips/id142.htm
Konan the Bavarian
« Reply #2 on: November 11 2015, 22:33 »
Thank you Lyra, I was hoping to see some Bavaria installs as well. I am trying to avoid additional deck fittings that will increase chance of stubbing toes, and reduce passage way along decks.
Cheers, Steven
« Reply #3 on: December 03 2015, 04:45 »
Hi Konan,
I would not recommend attaching the first block to the shroud base as this will increase the load on this critical point. The chain plates are designed to carry the mast and shroud loadings. Adding the upward and inward force of hte turning blocks would not be good. On the B40 2009 there is a pad eye or saddle attached to teh deck behind the chainplates with the turning block attached to this. The block is positioned so the mainsheet runs outside the jib track. Sorry I do not have a photo.
SV Synergy
