Author Topic: B36/2004 distribution panel - pin type definition  (Read 6723 times)
« on: October 09 2015, 15:42 »
The distribution panel has 2 connectors as attached.
I want to populate some of the spare circuits.
Anybody knows the exact definition of the pins used in this housing - they seem to be Molex type but slightly larger than the type used in PC power supplies
Querencia
Re: B36/2004 distribution panel - pin type definition
« Reply #1 on: October 10 2015, 20:30 »
Most of the parts for the boat are either Swedish, German or Italian, I'm not sure what the molex type connectors are,but all the stoppers,pulleys, turning blocks .etc are Rutgerson which is swedish, I would imagine that the type of molex connectors you are looking for are German     Ed
Querencia
« Reply #2 on: October 10 2015, 20:50 »
Check this out, It looks like they have the molex connectors for the Bavaria Panels
http://www.uchimata-shop.fr/6_bavaria-yachts           Ed
« Reply #3 on: October 10 2015, 23:14 »
They are from this range
http://www.te.com/usa-en/product-350736-1.html
http://www.te.com/usa-en/product-350784-1.html
The attached is my copy of my modified connectors, it may help.
« Reply #4 on: October 11 2015, 07:12 »
Thanks very much for the info.
« Reply #5 on: October 11 2015, 10:36 »
I think you will find the following info useful
http://www.autoelectricsupplies.co.uk/product/39
p/n 051311
« Reply #6 on: October 11 2015, 12:37 »
Quote
Thanks.
These are the thin pin type. The UNIVERSAL Mate n Lock are larger pins - I believe these are the correct type - http://www.autoelectricsupplies.co.uk/product/683
I also found them on EBay from a USA source. Shipping costs will probably define where I will get them from.
« Reply #7 on: October 11 2015, 12:46 »
Quote
Maybe I was wrong and the 2mm type are correct (the larger are 3.5mm) - need to check this on the boat  - anybody knows for sure?
« Reply #8 on: October 11 2015, 16:18 »
The ones I linked to are the type on my boat, buy them at CPC.
« Reply #9 on: October 11 2015, 17:12 »
The link is for the shells and I am looking only for the contacts - using your links as a starting point I can't find which contacts are used in them.
« Reply #10 on: October 11 2015, 17:32 »
My original info came from the boa website a few years ago.  I did obtain some 2mm to extent my lighting circuit on a B32
« Reply #11 on: October 11 2015, 19:07 »
Quote
Odd. Just measured the pins of the type used in old PC power supplies for the hard disk - they are 2mm and I clearly remember that they were a bit smaller than those used in the connector in the boat.
However, without having the boat connector in front of me, 3.5mm seems a bit too thick - will have to get to the boat and measure exactly and take it from there.
« Reply #12 on: October 11 2015, 23:01 »
I suggested CPC for a reason,  see the datasheet on this page, search it for the part numbers (for example 350736-1) and it tells you what contacts are available.
Alternatively, look at the Associated Products on the Farnell page then use the Manufacturer Part Number with CPC.
