Bavaria Yacht Info
The FREE Bavaria Yacht Forum
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Login
Register
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
Bavaria 41 water tank
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Bavaria 41 water tank (Read 6619 times)
Cathy Davies
Swab
on:
August 12 2015, 22:33 »
Dumb question I know but how do you switch from aft water tank onto forward one on a Bavaria 41? Can't find switch!!
Logged
Cathy Davies
Swab
Re: Bavaria 41 water tank
Reply #1 on:
August 12 2015, 22:37 »
And is there an easy place to find an instruction manual if your charterer hasn't provided one?!
Logged
Old Salt
Boat Model: Bavaria 33
Boat Year: 2015
Reply #2 on:
August 12 2015, 22:40 »
It is a simple 3 position valve, probably somewhere in the loo. You will find the pump and changeover valve in one place. It is clearly shown in the handbook.
Logged
Cathy Davies
Swab
Reply #3 on:
August 13 2015, 06:01 »
Mm - problem, as I thought I'd said, is no handbook, hence trying to source one online. Have looked for something resembling a valve in both heads without luck but will keep searching.
Logged
B41
Swab
Boat Model: Bavaria 41
Boat Year: 2003
Reply #4 on:
August 13 2015, 07:07 »
If you have a B41 3 cabin, the 3 way valve is in the port-side toilet. when you enter it there is at the right a small hatch ( small seat at shower). Open the hatch. In the middle at the bottom under the holding tank there is a red handle. Turn it to the left : Aft tank. To the right : forward tank.
Logged
Old Salt
Boat Model: B36
Boat Year: 2004
Reply #5 on:
August 13 2015, 08:13 »
Don't know this model, but basically you can do it by ear - turn on the water, listen for the noise of the pressure pump, locate it and most likely the 3 way valve is close to it.
Logged
Old Salt
34/2001 2cab
Boat Model: Bavaria 34
Boat Year: 2001
Reply #6 on:
August 13 2015, 20:28 »
OK, we're a B34/2-cabin but our switch is under the sink. Worth looking there too.
p.s. and ours is not near the pump
Logged
Administrator
Boat Model: 40 Ocean
Boat Year: 2001
Reply #7 on:
August 13 2015, 22:33 »
If it's this Bavaria 41 (Cruiser 41) you're talking about:
https://www.bavaria-yachtbau.com/sailing-yachts/cruiser-line/cruiser41.html#techdata
It appears to have only one (210 L) water tank. So it might be that you can't find the valve for the second tank because there isn't a second tank or valve. Otherwise, above hint to find the pump is good advice - the switch would be very near it (mine lives behind a little cabinet door in the aft cabin together with pump and pressure tank, but that's on a wholly different model).
Logged
(formerly)
Sailing Songbird
⛵️ Bavaria 40 Ocean (2001)
Old Salt
Boat Year: 2015
Reply #8 on:
August 13 2015, 23:55 »
Simple way of checking is to see if it has two fillers. One will be at the stern and the other at the bow.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Bavaria Yacht Info
Member Forums
Bavaria Yacht Help!
