Author Topic: Battery Charger for Bavaria 36  (Read 4513 times)
BillGiles
« on: August 10 2015, 13:07 »
Subscribers will be interested in this link which I found. It is for the battery charger for a 2003 Bavaria 36 - it took ages to find:
https://cdn.shopify.com/s/files/1/0658/7343/files/Instructions_A6_english.pdf?10272564971072232026
This is the Sterling Power Products charger.
It only mentions ordinary lead acid and gel batteries and I am trying to find out from the company if it is suitable for AGM batteries or what the settings are. Although I have seen that several subscribers have fitted AGMs without issue, but were they fitted with the Sterling charger?
Re: Battery Charger for Bavaria 36
« Reply #1 on: August 10 2015, 14:00 »
The "Battery Type" switch has 2 settings, marked "Standard" and "Gel/Sealed".  As AGM batteries are "sealed", you'd use the "Gel/Sealed" setting for AGM batteries.
