Seahorse7101
New member
I have a Volvo D2-75 turbo new in May 2013. Within 5 months the jubilee clip holding the charged air pipe was found to be lose by Volvo engineer. On next service it was found to be lose again and re-tightened. In October 14 I noticed it was lose again - this time Volvo said the pipe needed replacing because it had become contaminated with oil so would not grip. At this point Volvo were going to cover it under warranty. To replace the pipe the turbo has to be removed. On removing the turbo they found that the waste gate had seized due to light loading of engine, so would not cover the work under warranty. Turbo was sent away by Volvo for complete refurbishment at a cost of £500. Total repair bill £1850.00.
I subsequently found out from another dealer that the wastegate does not open until 2800 rpm my engine revs to 2700 which is within the recommended max revs in Volvo handbook. I took Volvo Penta UK to small claims court and they paid me back in full without admitting fault.The work was completed in January of this year. Within a month I could see the jubilee clip was being forced back, it was not lose. It appeared as if the pipe was expanding so pulling the clip back. Volvo dealer coming down next week to look, they are suggesting abrading the pipe so that clip gets a better grip. I am not sure this is the problem because I know of several D2-75 owners who have not experienced any of these problems and I am on my 2nd pipe.
The charged air pipe is about 8cm long, takes air from the filter through the charger to pressurise the air and then connects to the inlet manifold. The only other thing that connects to it is the crankcase breather hose. My feeling is that there is too much pressure in that part of the system. I have tried seeing it the wastegate opens at max rpm but cannot see the rod from the actuator moving.
Does anyone know what the problem maybe?
