Bav 39 Fridge info
Author Topic: Bav 39 Fridge info  (Read 6682 times)
MIA
Bav 39 Fridge info
« on: September 15 2015, 09:37 »
Does anyone know the manufacturer or a manual of the fridge unit in a B39 (2006), fan is not coming on have to give it a tap to move it.
Stevie
Re: Bav 39 Fridge info
« Reply #1 on: September 15 2015, 10:27 »
Mine's a Frigoboat by Veco, but that doesn't matter, because it's made entirely from standard parts, those being a Danfoss/Secop BD35 compressor, matching controller from the same manufacturer and the fans are bog standard industrial fans like those used to cool computers. They're widely available and come in standard sizes - either look up the spec of the original fan from the label or just measure the size. Only interesting bit is that they're 24 V fans on a 12 V boat - but as they're hooked up to the fridge controller, it may well be that the voltage is stepped up there (or they simply run slower/quieter).
MIA
« Reply #2 on: September 15 2015, 12:08 »
Excellent thanks, the fan was working perfectly until last weekend and every time I opened the fridge the fan was off, gentle tap and came on so must be sticking, that tells me its meant to be running if it starts with a tap.
Stevie
« Reply #3 on: September 15 2015, 12:47 »
Yes, the bearings go on those fans after a couple years, just like the computer ones. Both are cheap and easy to replace.
Baltic
  • Boat Model: B39
« Reply #4 on: September 15 2015, 19:42 »
Original B39 fridge.
Type probably Waeco CU-94.
Fan 120x120mm
« Reply #5 on: September 15 2015, 20:08 »
Fan 120x120mm
Nice. There will be a sticker on the other side of the fan with the model and possibly some specifications.
Ziffius
« Reply #6 on: September 16 2015, 08:09 »
Mia, do you mean the little fan inside the cooling plate in the fridge.
« Reply #7 on: September 16 2015, 08:28 »
That's the one I thought he meant.  It's probably still something like a computer fan and should be easy to replace (or maybe lubricate).
MIA
« Reply #8 on: September 16 2015, 10:26 »
Yes it's the small fan inside, I'll strip the controller down and test the fan, just didn't know who the manufacturer was.
Stevie
Baltic
  • Boat Model: B39
« Reply #9 on: September 17 2015, 19:43 »
MIA
« Reply #10 on: September 18 2015, 10:52 »
Excellent thank you, I'll check it when I get down to it
Stevie
