Engine room bilge pump
Author Topic: Engine room bilge pump  (Read 3140 times)
Lunty
  • Boat Model: Bavaria 37
« on: May 11 2021, 21:53 »
Hello I have just bought my 2001 Bavaria 37 does it have a bilge pump in the engine room she’s been fresh water for about a month and there was about 10 ltr of water in engine room
Re: Engine room bilge pump
« Reply #1 on: May 12 2021, 05:45 »
No engine bay bilge pump on our B40 of same vintage.
I would suggest observing raw water pump while engine is running, as well as other potential leak sources.
BR
Tommi
s/y Anniina
Lunty
« Reply #2 on: May 12 2021, 07:24 »
Thanks I will have investigation this weekend
« Reply #3 on: June 03 2021, 06:23 »
I’d check the exhaust system, particularly the silencer if it is still the original Volvo fttng with stainless ends. They are known to suffer from internal corrosion due to lack of oxygen. If it is the silencer thats leaking, don’t waste time or money on getting it repaired, or buying a Volvo replacement as they are too expensive and will only corrode again. Change it for a plastic silencer which will be much cheaper and probably last longer. Force4 chandlery in the UK have them at something under £80 last time I looked.
