Fresh water tank
Author Topic: Fresh water tank  (Read 2500 times)
Michtsui
  • Boat Model: Bavaria C 42
Fresh water tank
« on: May 01 2021, 10:47 »
Just bought a second hand Bavaria 42 built in 2005 - quite good.
But the water tanks (both) have never been cleaned and washed before (for 17 years). When I tried to open the plastic lid it is so tight and hardly be opened. Any tips?
Re: Fresh water tank
« Reply #1 on: May 01 2021, 11:22 »
The inspection cover is often very difficult to unscrew.  Some people make up a "spanner" with two pegs which fit in to the slots.  I've had success with a large pair of water pump pliers.  When you get it off, grease the O-ring with silicone grease before re-fitting the cover.
Michtsui
« Reply #2 on: May 01 2021, 12:28 »
Will try thanks
marioxp
« Reply #3 on: May 03 2021, 21:49 »
I cleaned mine with vinegar.
I poured 6L of the cheapest vinegar, fill with few liters of water, left it for a while and then drained it through taps.
After that I rinsed with water, several times with a smaller amount.
Vinegar is good because dissolves limescale well, it cannot corrode metals (like all other organic acids), it is not poisonus and it is cheap. But next time I will use citric acid, the same positive qualities but does not smell like vinegar.
I will additionally do disinfection with Izosan G.
Michtsui
« Reply #4 on: May 04 2021, 08:14 »
Thanks for the tips
artemis
« Reply #5 on: May 29 2021, 15:58 »
I went to a chemist and got the stuff for sterilizing beer and wine kits
Mike
