Power Outlets?
Author Topic: Power Outlets?  (Read 3380 times)
captpatrick211
  • Boat Model: Vision 40
Power Outlets?
« on: December 28 2019, 21:09 »
Good day everyone... not sure if these are meant for inverters or anything else I can plug in.  I'm hoping they are something I can use to charge my ipad while sailing or under power. tried plugging in the inverter but it doesnt fit... The holes appear a little larger than the 12v version on my navsta.  Any thoughts?  Thanks!
Re: Power Outlets?
« Reply #1 on: December 28 2019, 22:52 »
The one on the right looks like an ordinary 12v cigar lighter socket. Not sure about the other. However if there is a 12v supply there you could replace that socket with a USB socket. There are plenty on the market of roughly that size with either one USB and one cigar lighter or 2 USBs. However the cockpit is not a good location for an ipad charger - much better to have it at the chart table - unless you want to use the ipad for navigation.
captpatrick211
Re: Power Outlets?
« Reply #2 on: December 30 2019, 13:57 »
Thank you...  still no power to either of these that I can find so that deepens the mystery a bit.  I do like using the ipad for navigation when possible.  Thanks again!
elias
Re: Power Outlets?
« Reply #3 on: December 30 2019, 15:01 »
As a Symphony said cockpit isn’t the best spot to have plugs , you can find a battery pack , charge it and have it as a source . As about the plugs , dive in your hull and explore... many things to find !
Re: Power Outlets?
« Reply #4 on: December 30 2019, 20:15 »
Have you taken the fitting out to see if it has any wired attached to it? 12v sockets are commonly fitted to binnacles - both my Bavarias have had them fitted at the factory. sometimes they are just a spur off the compass light.
captpatrick211
Re: Power Outlets?
« Reply #5 on: January 02 2020, 18:09 »
Thanks everyone - I like the battery pack idea.  Tried everything I could think of yesterday outside of hull exploring and no luck in getting power identified.  So, looks like I'll practice some yoga moves today and see what's up!
Keweetoo
  • Boat Model: Bavaria 35E
Re: Power Outlets?
« Reply #6 on: January 07 2020, 14:45 »
I fitted one of the Scanstrut waterproof USB chargers to the helm to power my iPad. It fitted into the hole through the binnacle left by a previous 'cigar lighter' type power socket. Just connect to 12v fused supply. The advantage of these units is the lid closes around the outlet and wires to make a waterproof enclosure even in the wet.
https://scanstrut.com/products-22/waterproof-dual-usb-charge-socket/sc-usb-02-new-rokk-charge-waterproof-usb-socket-detail
Keweetoo
