What is your best improvement on the boat and why?
Author Topic: What is your best improvement on the boat and why?  (Read 40892 times)
Re: What is your best improvement on the boat and why?
« Reply #50 on: July 26 2019, 08:18 »
Thanks Jeff!
Atlantica
« Reply #51 on: July 27 2019, 19:12 »
I’ve sent notes on my fridge insulation to those asking. It’s a bit long, so if anyone else is interested, let me know.
Chill
I would like to have your notes too. Thank's a lot in advance!
Cheers,
Juha
B38, 2003
kavok
  • Boat Model: 40 Cruiser
« Reply #52 on: July 31 2019, 23:22 »
Chill
Yes Chill, I am very interested about insulation.
Angelo
kavok
« Reply #53 on: August 14 2019, 21:58 »
Modified rudder top bearing plate.
Due to a banging noise from rudder on my Cruiser 40 2008 twin wheels. The  upper rudder bearing aluminium plate slip sideways due to the elongate holes. The two stop screws are not efficient when movements came from rudder (when load was reversed on the rudder.), I changed these two Parker little screws with through 6 mm bolts and nuts. Also I  add up an down two big aluminum custom washers  8 mm thickness, bolted whith six 6 mm bolts ad nut. All side movements are now impossible. I also changed the two bearings with new Jefa roller bearings and adjusted chains tension not too loose not too tight. Now sensibility and lightness windward are excellent.
cegri
  • Boat Model: Bavaira 39C
« Reply #54 on: December 19 2019, 12:01 »
Nice topic... As a new member, let me reactivate it:
- Thermostatic mixing valve for water heater. Avoids scalding. Also saves valuable hot water lost trying to adjust temperature.
- Sea water pump that feeds kitchen sink. Not the manual foot pump! A proper elecrical unit.
- 600 Watt solar panels
- Folding helm for the B39C, thanks to previous owner
- Daewoo wall-mounting washing machine
- Bigger cockpit table from Tischlerei Kurt Behn KG
- Remote controlled windlass
