water tanks level indicator....
Author Topic: water tanks level indicator....  (Read 2388 times)
Porquerolles
  • Boat Model: Bavaria 42 Vision
  • Boat Year: 2019
« on: August 12 2020, 16:36 »
Hello,
We have a problem with the display of the level of the water tanks. In principle, the dashboard indicates the water level in the front tank and in the rear tank (see photos), sometimes, for no apparent reason, the table only indicates the level of the rear tank ... have you ever encounter this type of problem? and if so, how did you resolve it?
Thank you for your feedback.
Cordially.
JoAnn
  • Boat Year: 2016
Re: water tanks level indicator....
« Reply #1 on: August 13 2020, 11:29 »
I occasionally have a similar problem.  I just switch the master house battery switch off and back on to fix it. Had the problem since new and power reset has fixed it every time.
Porquerolles
  • Boat Year: 2019
« Reply #2 on: August 14 2020, 15:36 »
Thank you for your response.
I did exactly like you to fix the problem.
Have you any idea of the origin of this problem ?
Best regards
