Fuel Tank Sender - Dip Tube
Author Topic: Fuel Tank Sender - Dip Tube  (Read 12407 times)
Re: Fuel Tank Sender - Dip Tube
« Reply #25 on: October 29 2022, 20:13 »
I found these two with a quick search:
https://www.ferroberlin.de/philippi-turotest-analoganzeige-fuel-52mm.html
https://yachtzubehoer24.eu/hersteller/philippi/gesamtprogramm/1180/philippi-instrument-fuel-52mm
It may also be possible to swap the labelplate from the broken one to a new one, as the gauge is likely the same :)
Sailpirate
  • Boat Model: Bavaria 31 Ocean
« Reply #26 on: October 30 2022, 04:26 »
Thanks, I ordered from both and had to return as each time I received the lineal version, (see last photo) although on their webpage they show the non lineal version😭
The pessimist complains about the wind.
The optimist expects it to change.
The realist adjusts the sails.
« Reply #27 on: October 30 2022, 09:02 »
Did you try the importer, Philippi directly? Might want to call them first to ensure they send the right thing: https://www.philippi-online.de/produkt/fuel-water-52/
Otherwise you could try getting in touch with Turotest in Brazil, the manufacturer: https://turotest.com.br
Or like I said, look into swapping over the dial from an existing one.
