Rudder Bearings
Author Topic: Rudder Bearings  (Read 63784 times)
Monique
Re: Rudder Bearings
« Reply #25 on: January 31 2012, 21:12 »
I am upgrading some items on Pegasus... one of them is the lower rudder bearing which was seized in the cage.
I had a quote of north of 600Euros from Bavaria.... plus VAT.
Guess what? I am having one manufactured by XPC bearings in the USA for a fraction of the Bav price. Made from Vesconite too which does not absorb water.... hence unlikely to seize. Total price including Customs and Delivery should be less than 1/3 the price.
Why do yacht builders think they can fuque us like this and expect our return business?
I suspect all other yachts may need this service sooner or later, hence this post.
To make it easy for XPC to produce a perfect fit, take out your old bearing and ship it to them... presto, you will get a clone ...
Happy customer!!!
PagetalPaul
Re: Rudder Bearings
« Reply #26 on: February 14 2012, 09:18 »
On my 35, when out of the water, there is noticeable but not excessive movement at the lower bearing when the rudder is moved by hand from side to side, and none at the top. When in the water and the rudder is forced up by buoyancy there is considerable float of the emergency connector within it's circle of movement. Although nothing is felt while sailing, it's all beautifully smooth, I guess my top bearing needs attention? How much can be done from the top with the rudder in place?
I have a 34 with some sideways movement (say 5mm).  Assumed it was bearing wear and planning to replace bearings during winter.  I also suspected that adjustment of the top bearing might sort the play out as I was told the pipe the shaft goes into tappers and that taking up the slack on top removes play at bottom?  (note no apparent top bearing slackness...do sometimes feel some vibration from rudder as put on way under engine...is that normal?)
If it is sideways play on the rudder shaft itself, that it likely to be sorted by tightening the bearing. Can be easily done, best with two people so that one can take some of the weight from below as it is tightened from above. (Note: this best done on the hard!). Sure could be done on the water too.
If you are talking about slack in the steering, ie movement before action, then that is a cable-tightening job, again easily done (especially if you are small and agile - lol) by centreing the wheel and then taking up the cable slack on each side of the sterring quadrant below the cockpit floor in the rear lazarette, reach via starboard rear cabin hatchway. You'll need an adjustable wrench or a set of reasonable spanners, and I suggest gloves as there's sharp metal and loose fibreglass down there.
Good luck .......
Anthony
Re: Rudder Bearings
« Reply #27 on: April 01 2012, 05:30 »
Interested in your exoperience as I have a similar problem with my 2001 Bavaria 40.
How long does it take to get the replacement bearings from XPC?
I am in Brisbane Australia.
Tommi
  • Boat Model: Bavaria 37
Re: Rudder Bearings
« Reply #28 on: May 06 2012, 20:06 »
This spring the steering on my Bavaria 37 2006 became very stiff. Narrowed the cause to the lower bearing and by dropping the rudder and removing the plastic bearing noticed slight corrosion of the aluminium housing enough to cause the stiffness. Removed the plastic bearing, cleaned the housing, lubricated the housing, put the bearing back. Installed a small zinc to resist corrosion.
Steering now like new.
russ
  • Live the Dream
  • Boat Model: Bavaria 42 cruiser
Re: Rudder Bearings
« Reply #29 on: June 10 2012, 06:41 »
Hi I understand you ordered new bearings from XPS. Did you send him your old ones? How did he know what size they were?
Sweet As
Re: Rudder Bearings
« Reply #30 on: July 04 2012, 02:30 »
I can detect a tightening of the steering system on our 2004 Bav36. The autopilot no longer controls the helm as smoothly as it once did and there is an audible squeak coming from the bearing.
Reading through the posts above, I suspect that the bearing has swollen to a point that it has started to interfere with the smooth movement of the post. I am making enquiries to XPC regarding supplying vesconite replacements for me in Australia. I will be travelling to Europe and the UK next month and would be intertested to learn of potential options for replacements that I may be able to pick up while there.
Can anyone please post to the forum a step by step procedure for the bearing replacement. It is not an area of the yacht that I have spent much time on to date. Even a schematic of the bearing and rudder post arrangement would help.
Thanks,
Sweet As
Bav 36
Otia
Re: Rudder Bearings
« Reply #31 on: July 05 2012, 20:07 »
Good luck .......
I'm not sure to understand what you mean by tightening the bearing; can you explain in more details please?
I also don't understand how tightening the assembly vertically can solve sideways slack. Again can you explain?
I'm not too familiar with the rudder shaft/bearings assembly, I never worked on it before.
I have a B38 2004 commissioned in 2005.  In the last few weeks I sailed her (I sail from Nov to June in the Caribbean's) I could hear an occasional knocking sound from the rudder shaft area.  So when I got her on the hard I inspected the rudder and noticed sideways slack.   The steering is not tight as others have experienced.  Is it just a case of tightening the bearing?
I had planned to change the bearings before the next season.  Reading from the experience of many others here, may be it is time for me to change those bearings anyway?
Sweet As
Re: Rudder Bearings
« Reply #32 on: July 10 2012, 02:59 »
In discussion with someone well experienced with Bavaria maintenance I learned of another cause of tightening steering. The aluminium bearing housing can corrode and swell, particularly if it is exposed to copper based antifouling.
Apparently the countermeasure is to paint the housing and a surrounding buffer zone with non Cu based paint (as is done around the sail drive leg).
Is this common practice?
Sweet As
Bav 36
Steve Cronin
  • Boat Model: B42AC
Re: Rudder Bearings
« Reply #33 on: July 26 2012, 13:59 »
I'm looking for a source for rudder bearings for my 2003 Bavaria 44...
I bought mine from Bavaria, contact Leszek Kleczka Tel.: +49 9334 942 1930 Fax: +49 9334 942 1530
To give you an idea of price, for a 2000 Bavaria 47 the parts are as follows (August 2010 prices, all plus VAT):
Lower rudder bearing Art.:  315238 price 380 ?
Lower rudder bushing Art.:  304106 price 165 ?
Upper rudder bearing Art.:  315206 price 159 ?
Upper rudder bushing Art.:  304105 price  60 ?
You need to quote your HIN when ordering.
Be careful when ordering from the factory. I have done it twice now, once for a stanchion which was different in design from what I thought I had ordered and the other, for a pair of rudder bearings and a lipseal only got one out of three correct. The order also took from February until June to arrive and even then to my business address NOT out to Corfu where I was. As on dismantling the stock assembly I concluded that the bearings didn't need replacing anyway, all I needed was a seal. Bavaria had charged me ?130 for this (& it was the wrong size) yet I was able to source it locally in Corfu for ?22.
Correct adjustment was all that was required for these substantial self aligning bearings. Ideally you need two strong blokes to drop the rudder onto the hard and replace it or you can struggle with a pile of three old car tyres!
I WILL have a couple of bearings for sale soon since the "agent" who arranged the deal now denies any liability in my being sent the wrong ones by the factory.
Steve Cronin
sailingallover
  • Boat Model: cruiser 42
Re: Rudder Bearings
« Reply #34 on: July 25 2015, 18:45 »
Has anybody found a way to get the actual dimensions of the rudder bearings or and decent aftermarket replacement source? Please do not simply post a Bavaria dealer. They want outrageous prices and I am in the Caribbean.
Spirit of Mary
Re: Rudder Bearings
« Reply #35 on: July 25 2015, 21:54 »
In Europe Jefa can supply replacement bearings for all Bavaria types. Their bearings are roller type bearings. Owners who replaced the bearings by the Jefa roller type are happy with the smooth running. Maybe not cheap but good
I think the main problem with the original bearings is the corrosion of the lower bearing housing for the self aligning ball. The bearing itself is made of POM which, same as Vestonite, does not absorb any water. So there is not the problem.
Ger
Re: Rudder Bearings
« Reply #36 on: July 26 2015, 06:07 »
Thought I would drop my 2 cents regarding rudder bearings, as some time they may not require replacement (or at least not immediately).
Two years ago, in the middle of a 350miles passage the rudder seized very badly after about 100 miles - autopilot could not steer at all and by hand it was very very stiff.  Had to hand steer for the rest of the passage - luckily we were a crew of 4. Upon arrival I tried to find a replacement bearing. No one had it in stock and considering delivery time and installation, that meant loosing more than a week of vacation, so I searched the net for alternative "first aid" solutions. One of them suggested to simply oil the bearing.
Crawl into the lazarette and loosen the top retaining band of the rudder shaft seal. Insert between the seal and the shaft the thin red tube that comes with any WD40 can. Spray a generous amount of wd40 into the seal - this is what I had, but I guess other lubricants may be good as well - one of the posters mentioned that they used olive oil because they had nothing else.  At first there was no change, played with the wheel back and forth but the wheel was still very stiff. Went to sleep and the next morning the wheel was completely free - even smoother than I ever remembered. Just to make sure I sprayed again after 24 hours.
Continued for additional 500 miles on that trip, have been sailing for the last two years and still did not replace this bearing.
I did make some searches for alternative manufacturers and the 2 that came up were already mentioned in this thread.
Re: Rudder Bearings
« Reply #37 on: July 26 2015, 09:57 »
Well done Lyra, I have done this as part of my lift out maintenence for years, I hope more Bav owners do the same. I put engine oil in.
Bav 38
Spirit of Mary
Re: Rudder Bearings
« Reply #38 on: July 26 2015, 10:06 »
Bav 38
I would be a little hesitating doing this. Is the rubber tube oil resistant. Normally it is not required in this application and the better material would be EPDM (not oil resistant) but excellent water resistant!
Did you experience any weakening of the material?
Ger
Re: Rudder Bearings
« Reply #39 on: July 26 2015, 11:16 »
The oil does not stop in the rubber tube it goes around the offending bearings and runs out when you lift the boat out of water.
You don't have to do this, your choice.
I have done it each year for 9 years, it works.
Bav 38
Re: Rudder Bearings
« Reply #40 on: July 26 2015, 18:14 »
Dear all
Although I have read many mentions of various oil-type liquids being put into the rudder tube, and everyone agreeing that it works (and I'm going to do the same!) but I don't actually understand how it's working. Surely, the oil works its way round the bearing when out of the water but the moment the boat goes back in, doesn't the seawater flood back round the bearing and the oil float to the surface? Or am I missing something? Confused...  ::)
Re: Rudder Bearings
« Reply #41 on: July 26 2015, 19:16 »
Well, actually it seems to make its way even when the boat is in the water - I did not take the boat out of the water for my "repair". I assume that there is very little, if any, circulation of water in the tube so I guess the trapped water + oil make some kind of emulsion that maintains the lubrication.
Re: Rudder Bearings
« Reply #42 on: July 26 2015, 20:54 »
Thanks, Lyra. Well, everyone says it works and that's as good an explanation as I'm likely to find, so I'm gonna do it too. Hmm, I wonder if the missus will notice the lavender bath oil is missing...  ;D
Mick
Re: Rudder Bearings
« Reply #43 on: August 06 2015, 09:41 »
Jaffa make replacement bearings for Bavaria. Pull up their website and the info is there. I have replaced the lower bearing with a roller assembly and a co entail bearing on top. No issues and reasonably priced here in Australia. Mick.
Trapeze Artist
    • Little Hotels
Re: Rudder Bearings
« Reply #44 on: August 07 2015, 22:15 »
I had quite a lot of movement in the rudder on my 2006 30. There is a big round "nut" at the top of the rudder stock, found by lifting the cover to access the emergency tiller point. This is turn is locked by a screw which distorts the thread. Just undo the locknut, then put a big pin wrench onto the nut and tighten it a bit. Mine needed about 3/4 of a turn to get rid of all the play. I did the job on the hard so it was easy to adjust the nut a bit, run down to check the play, go back and adjust some more ....... etc. I think it would be very difficult to do the job properly in the water, though you could probably improve things a lot. I bought the pin wrench on eBay for about £12, but it does take quite a bit of searching to find the right one amongst the numerous small ones for angle grinders, plus a few outrageously expensive ones.
tuomaskk
  • Boat Model: 30 Cruiser
Re: Rudder Bearings
« Reply #45 on: August 17 2015, 07:11 »
Not Jaffa, I think Mick means JEFA.
Danish company, you can find all necessary from there. Link to webpage below.
http://www.jefa.com/steering/steering.htm
BR,
-t
ZhuHai
Re: Rudder Bearings
« Reply #46 on: September 03 2015, 01:35 »
This site which seems to belong to Bavaria Yachts lists parts available per boat model:
here for rudder bearing
https://www.bavariaplus.de/en/produkt/view/agxlfmJhdmlzLXZpdXJyFAsSB3Byb2R1a3QYgICAwIj7jwoM#article-details-agxlfmJhdmlzLXZpdXJyFAsSB2FydGlrZWwYgICAgOm_5QoM
Re: Rudder Bearings
« Reply #47 on: September 03 2015, 07:33 »
Quote
These look like bearings and dimensions for newer (current?) models - the B36 is shown as 84mm while my boat is 60mm (probably similar to what is listed as 35 match).
