Cockpit table for Bavaria 34 (and others?)
Author Topic: Cockpit table for Bavaria 34 (and others?)  (Read 19706 times)
Boatname
« on: June 02 2016, 13:58 »
I have just seen these photos on BOATSHED ... yes, they own them and I hope it's ok to post them here with due accreditation.
Does anyone know where I can buy the table?
Thanks.
Re: Cockpit table for Bavaria 34 (and others?)
« Reply #1 on: June 02 2016, 14:30 »
Don't know where to buy that particular one, but you can get high quality teak ones (plus the Lewmar mounting kit) from www.kjhowells.com
Boatname
« Reply #2 on: June 02 2016, 14:34 »
Thanks but our boat is FULL.  Absolutely no space for the table you mention which is why I like the idea of the one in the photos.
Diga
  • Boat Model: Bavaria 45 Cruiser
« Reply #3 on: June 02 2016, 14:48 »
I am very happy with our cockpittable from Cockpitbord.dk (www.cockpitbord.dk)
Boatname
« Reply #4 on: June 02 2016, 15:06 »
But that appears to be mounted on a large moulding.
Thanks but I REALLY want the one in the photos  :)
mikeiso1192
« Reply #5 on: June 02 2016, 17:39 »
Hi Boatname
I believe that Symphony is referring to this table which is available from K J Howells.
I have no interest in them just a satisfied customer.
See the attached of my table which I installed this May.
Mike
Boatname
« Reply #6 on: June 02 2016, 18:01 »
That's nice, did you use their mounting kit?
Genuine Whitlock Table mount Kit - Bavaria/Royale
http://www.kjhowells.com/89400246
If so was it complete, hinges, screws etc?
And did you take a chance screwing into the pedestal or take the instrument panel off to see what was going on?
« Reply #7 on: June 02 2016, 18:31 »
I think it's a discontinued Lewmar product.  You may be able to find one in stock somewhere still - it's listed here http://www.sailtec.net/lewmar-composite-cockpit-table-double-leaf-enguard-pedestal-p-3207.html?language=en&currency=GBP
Boatname
« Reply #8 on: June 02 2016, 18:55 »
Thanks for tracking that down but £ 743.74 ?
Good grief, I think I'll go with Symphony and Mikes suggestion.
Thanks all.
« Reply #9 on: June 02 2016, 19:00 »
But you REALLY wanted it!  :))
Boatname
« Reply #10 on: June 02 2016, 19:06 »
 ;D :P :P
Diga
« Reply #11 on: June 02 2016, 20:39 »
Actually you will find exactly what you are looking for at cockpitbord.dk - in teak however....I have one like the one you are looking for at my Bav. 36
Diga
« Reply #12 on: June 02 2016, 20:46 »
Like this....
Boatname
« Reply #13 on: June 02 2016, 21:17 »
Ah, ok, I just saw the first couple of photos on their website. Thanks
« Reply #14 on: June 02 2016, 21:19 »
Equally expensive though, isn't it?
mikeiso1192
« Reply #15 on: June 02 2016, 22:26 »
Hi Boatname
Sorry about the sideways pictures my PC just goes not cope with the auto-rotate feature on my phone.
The kit I bought is as you specified - Whitlock table mount kit - Bavaria/Royale and Cockpit 3 leaf Table (610 x 710 open 355 closed).
All fitted reasonably easily (measure twice cut once principle).
It bolts through the pedestal so you need to unscrew the instrument fascia to access the inside to do up the nuts. I took the precaution of adding some ss washers on the inside to spread the load.
I just need to do some gelcoat work to tidy up where the old cockpit table was fixed.
Mike
Boatname
« Reply #16 on: June 02 2016, 22:56 »
That's brilliant Mike, thanks. The first ones I saw on Symphonies link showed the detachable table with the very clever mounting and arm but as I said we just don't have space to store that. I should have explored further.
We live on our boat for 5 months and with bikes, kayak, Tinker, sailing gear, scuba gear, mast ladder ... the list goes on ... hardly any space for the gin   :kewl
So I've sent an email to Howells querying availability.
Thanks to all for the input.
« Reply #17 on: June 02 2016, 23:19 »
Pretty sure you will find them in stock - he had them last time I was in the shop a couple of weeks ago.
Boatname
« Reply #18 on: June 03 2016, 11:44 »
A quick reply from Howells " I try to keep a small stock, but sometimes Whitlock/Lewmar can have long lead times when we put in our order.  If you are only in the area for a short period of time, it is work ordering approx 2-3 weeks before collecting to allow for any lead time they may have"
Mike,
Do the screws ringed in red fit into captive sleeves from the inside of the binnacle?
Does the fitting ringed in green just screw into the pedestal and hang down when the table is in use ... pull down and clip onto the edge of the table when not in use?
I can't see that you have used it.
Thanks again
mikeiso1192
« Reply #19 on: June 03 2016, 23:05 »
Hi Boatname
The items ringed in red is the support bracket for the leg of the table which is fastened to the face of the pedestal (I used bolts for this). This bracket has a screw adjustment to fine tune the level of the table. I think the manufacturer intended it to be bolted; access to the nuts for these bolts can be made through the hatch beneath the engine throttle/gear control.
The items ringed in green is a stowage bracket which clips to the bottom edge of the table when in the vertical to stop it banging about whilst the boat is in motion. When the table is in use it just hangs at the base of the pedestal and does not get in the way. I don't think it was fitted when I took my pictures.
The instructions provided were a bit sketchy so you do need to figure some of it out for yourself.
But all in all I'm very pleased with the result.
Hope that helps
Mike
Boatname
« Reply #20 on: June 03 2016, 23:49 »
It helps massively Mike, thanks. I am the Frank Spencer of DIY and measuring 7 times and cutting 5 is my norm. :)
Now, I promise, one final question, I really like the way your table fits on the binnacle, you haven't quite got to where the binnacle starts to slope forward.
What size table did you buy?
Right.
Getting ready for haul out tomorrow to have my saildrive gaiter changed ... chatting to the mechanic ... another one who has never seen a need for it but hey ho ...
mikeiso1192
« Reply #21 on: June 05 2016, 00:39 »
Size of my table is as per my earlier post.
610mm long by 710mm wide when open 355mm when closed.
It fits just under the "contour" of the binnacle but above the join between the top and bottom halves.
Mike
« Reply #22 on: June 05 2016, 10:55 »
It looks just like mine from Sheraton marine cabinet (£180 without mounting kit): http://sheratonmarinecabinet.com/epages/c6813606-9180-4f93-a01d-67854a5c6cfd.sf/en_GB/?ObjectPath=/Shops/c6813606-9180-4f93-a01d-67854a5c6cfd/Categories/3
Someone painted it white, most likely due to weathering of the veneer. I've been told the current models are solid teak.
Boatname
« Reply #23 on: June 05 2016, 18:07 »
Mike
Sorry Mike, trying to read all this on a phone in a cafe  ::)
jonrarit
« Reply #24 on: June 07 2016, 15:29 »
Many thanks for all the info folks but the off the shelf tables are far from cheap and outwith my budget.....so I made my own
Such a difference over the standard one with the front extension piece being removable and stowed on it's own bracket in the aft cabin.
Pictures attached
What do you think?
JR
PS to the original OP .... I have the original white lewmar table still if you're still looking for one ....going cheap :)
